Why can a cyclic symmetry analysis issue many warning messages of the following type? “Term= 3 on CE number= 17 is not active on any element. This CE is ignored.â€
March 17, 2023 at 9:00 amFAQParticipant
One possible cause is that the edge nodes are attached to elements with only a translation dofs, but there are elements in the model (e.g., beam or shell) with translation and rotational dofs. If so, the solver will write cyclic symmetry constraint equations for non-existent rotational dofs. This problem can be alleviated by using the CYCOPT command to specify the dofs to be used. For example: CYCOPT,DOF,1,UX,UY,UZ ! For pair 1 CYCOPT,DOF,2,UX,UY,UZ ! For pair 2
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- Structural modeling with ANSYS Workbench Mechanical
- What is the difference between shell 63 and shell 181?
- What might cause the “Error: HResult E_Fail has been returned from a call to a COM component” in SpaceClaim?
- Why would I get non-zero force reaction in X direction in 2D axisymmetric model?
